Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
424 error and full file name
3 REPLIES 3
153 Views, 3 Replies
I get a 424 error when trying to open a form (frm). Help shows what could be
wrong with the code. I've tried everything but the right thing to correct
the problem using what comes up in help, several times to no avail. If
someone has been there done that could point me to things look for it would
be much appreciated.
What is the best way to get the fullfilename? I have tried the code posted
on this ng, but none seem to work. I am trying to get the filename into a
list box.
3 REPLIES 3
Phil
I will post a small example to IVCF. Look for a post titled "Full File
Name"
Generally it is best to post a small snip of the code that is failing,
especially the line that it stops on in order for people to be able to
help.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Phil A" wrote in message
news:0854E0AE97DA552B1FF88F1CE5D62CE7@in.WebX.maYIadrTaRb...
could be
correct
would
posted
into a
> list box.
Kent,
I think you have got a small typo in your Module1, you forgot the "e" of
"Mode" in vbModeless
Here's the correct code for Module1:
Option Explicit
Public Sub Showfilename()
UserForm1.Show vbModeless
End Sub
"Kent Keller" wrote in message
news:16A0CD857B8CB6A03D49DA7B62F97607@in.WebX.maYIadrTaRb...
> Phil
> Name"
> help.
> Kent Keller
> Assistant Moderator
> could be
> correct
> would
> posted
> into a
> > list box.
Thanks Teun. Funny, I would have expected that to throw a error.
Kent
Assistant Moderator
"Teun Ham" wrote in message
news:82A823997D28A6C118ED913FCFE90586@in.WebX.maYIadrTaRb...
> Kent,
