Kent,
I think you have got a small typo in your Module1, you forgot the "e" of
"Mode" in vbModeless
Here's the correct code for Module1:
Option Explicit
Public Sub Showfilename()
UserForm1.Show vbModeless
End Sub
"Kent Keller" wrote in message
news:16A0CD857B8CB6A03D49DA7B62F97607@in.WebX.maYIadrTaRb...
> Phil
> I will post a small example to IVCF. Look for a post titled "Full File
> Name"
> Generally it is best to post a small snip of the code that is failing,
> especially the line that it stops on in order for people to be able to
> help.
> Kent Keller
> http://www.MyMcad.com/KWiK/Mcad.htm
> Assistant Moderator
> Autodesk Discussion Forum Moderator Program
> "Phil A" wrote in message
> news:0854E0AE97DA552B1FF88F1CE5D62CE7@in.WebX.maYIadrTaRb...
> > I get a 424 error when trying to open a form (frm). Help shows what
> could be
> > wrong with the code. I've tried everything but the right thing to
> correct
> > the problem using what comes up in help, several times to no avail. If
> > someone has been there done that could point me to things look for it
> would
> > be much appreciated.
> > What is the best way to get the fullfilename? I have tried the code
> posted
> > on this ng, but none seem to work. I am trying to get the filename
> into a
> > list box.
