I have downloaded AutoCAD 2015 from the Subscription Center
https://autodesk.secure.force.com/Customer/apex/LEM_myProductDownloads
Brouwser download
And i get "AutoCAD_2015_English_Win_32bit_dlm.sfx.exe" as explected.
But when I dubbleclick the exe file to extract it, it tells me that the exe file is not a valid 32-bits application.
And indeed, when I dubbleclick the file on a Win7 64 bits it extracts.
Then I was able to start the Setup again from a 32-bits Win 7 in order to create my 32-bits deployment.
Strange though, i need a 64-bits machine, only to unpack the Sfx.exe...
Solved by pendean. Go to Solution.
If you are just looking for a product download you should be able to find it at the Autodesk Customer Service Virtual Agent:
•In the preferences or options area of your preferred browser, remove pop-up blockers and allow access to all *autodesk.com sites.
•In the preferences or options area of your preferred browser, delete cookies, temporary internet files, and history.
1. Turn off your personal firewall or VPN, if you use one.
2. Disable UAC
3. Close and reopen your preferred browser.
4. Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
5. Select the choice "Download Links".
6. Select your product, then variant, then version as applicable.
7. You should now be presented with the choice to download your software.
