Installation & Licensing
有關REVIT視窗排列問題
2 REPLIES 2
1148 Views, 2 Replies
有關REVIT視窗排列問題
您好:
因為我是MEP使用者因為常要多視窗繪圖(平.立.剖)若有4個視圖窗時鍵入<WT>只能水平排列,每次都要手工去調整視圖窗,很浪費時間,是否未來會有垂直排列視圖窗的機制(因為大部份都軟體都有此功能)
謝謝
2 REPLIES 2
TravisNave
在Revit MEP的論壇,在這裡,你可以嘗試要求:然而,你可能會發現很難獲得在中國的反應。祝你好運!
http://forums.autodesk.com/t5/Autodesk-Revit-MEP/bd-p/188
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
lanl
Dear stacy591220, 目前Revit的WT平鋪窗口功能無法進行自定義操作,比如將四個窗口同時豎直排列等。您可以到下面的網站,提交功能需求。將鏈接裏的Product選擇為Revit MEP,然後填寫您需要的功能,進行提交。相關的團隊會認真查看所有提交上來的這種軟件的功能需求的。http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794 Currently, there is no customization tool for the WT function to place multiple views vertically. I would encourage you that report such wish list here: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794 You can use the form in the link to tell us what you think about our products, their features, and any improvements you would like to see. You can select Revit MEP in Product field, then wrtie the detail function you need.Then related people will read all the feedback recieved and take what our customers have to say very seriously.
Lei Lan
Administrator Productivity
