Installation & Licensing
Yes or No - Install INV 2013 along side 2012
4 REPLIES 4
Myoula
421 Views, 4 Replies
Please, this should be a yes or no question:
Can I install standalone Autodesk Product Design Suite 2013 alongside exisitng Autodesk Product Design 2012 and then uninstall 2012 Suite without damaging new 2013 install?  Want to do this so 2013 inherits settings, projects, mapped folders, etc from 2012 before doing 2012 unistall. Will the Windows Control Panel uninstaller damage 2013 install when uninstalling 2012 or is there another way of cleanly doing uninstall, or must I first uninstall 2012 and recreate environment manually after 2013 install to be safe??
Win 7 64 bit
4 REPLIES 4
TravisNave
in reply to: Myoula
Yes.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
DarrenP
in reply to: TravisNave
yes you can install both
i would use the uninstall tool that comes the product design suite
start>all programs>autodesk>product design suite 2012
DarrenP
Myoula
in reply to: DarrenP
Yikes - you guys are quick!!
That's sort of what I wanted to hear - use the Autodesk uninstaller instead of Control Panle uninstaller.
Thanks much!
DarrenP
in reply to: Myoula
the uninstall tool is better because you can uninstall the whole suite at one time instead of uninstalling one by one through windows control panel
DarrenP
Administrator Productivity
