I am facing this problem ...
Erro parsing Xaml file: 'Initialization of 'WpFCustomControls,MaxRibbonControl' threw an exception. 'Line number '42239' and line position '3'
i tried the solution woth renaming the file but the error still exist..
please help me!
Michailidou49
Welcome to the community...
What operating system are you trying to install this on? If Win 10, I don't think the 3ds Max 2015 supports it.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi did you manage to resolve this? i am facing the same problem and dont know what to do?
Not sure what you have tried but did you do this already?
Mark Lancaster
HI
I have the same problem! 3ds max design 2015, Windows 8.1
Every time I run the program, this error occurs: Error parsing Xaml file: 'Initialization of 'WpFCustomControls,MaxRibbonControl' threw an exception. 'Line number '42239' and line position '3'
Then, when I press OK, the following window appears: The main Ribbon configuration file is possibly corrupt. Reset to factory defaults?
I press Yes.
Again: Error parsing Xaml file: 'Initialization of 'WpFCustomControls,MaxRibbonControl' threw an exception. 'Line number '42239' and line position '3'
Press OK
After this program starts
What is this error? What should I do to fix this?
Thank you in advance for your help
