Installation & Licensing
Winows 8.1 Inventor 2014 installatoin fail result=1619
1 REPLY 1
mudry.adam
222 Views, 1 Reply
Hi.
I was trying to install Inventor Pro 2014 on Windows 8.1 x64 but it always end and says:Inventor 2014 fail.png
When i open INSTALLATION LOG FILE there is this text:
2014/11/27:20:17:28 Adam JOHNY === Setup started on JOHNY by Adam ===
2014/11/27:20:17:28 Adam JOHNY Path_Length: 182
2014/11/27:20:17:28 Adam JOHNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/11/27:20:17:28 Adam JOHNY Launch
2014/11/27:20:17:28 Adam JOHNY CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_Set... /SN 900-42080315 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/11/27:20:17:28 Adam JOHNY Current Directory C:\Users\Adam\AppData\Local\Temp\_AIC6E6.tmp
2014/11/27:20:17:58 Adam JOHNY === Setup ended ===
2014/11/27:20:17:30 Adam JOHNY === Setup started on JOHNY by Adam ===
2014/11/27:20:17:30 Adam JOHNY Path_Length: 182
2014/11/27:20:17:30 Adam JOHNY Current Directory C:\Users\Adam\AppData\Local\Temp\_AIC6E6.tmp
2014/11/27:20:17:30 Adam JOHNY Launch
2014/11/27:20:17:32 Adam JOHNY Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/SETUP_...
2014/11/27:20:17:57 Adam JOHNY Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/SETUP_...
2014/11/27:20:17:57 Adam JOHNY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Adam\AppData\Local\Temp\_AIC6E6.tmp\Setup\InventorUI.dll
2014/11/27:20:17:57 Adam JOHNY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/11/27:20:17:58 Adam JOHNY PageOpen LaunchDialog
2014/11/27:20:19:05 Adam JOHNY Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/11/27:20:19:05 Adam JOHNY Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/11/27:20:20:04 Adam JOHNY PageOpen LicenseDialog
2014/11/27:20:20:04 Adam JOHNY PageOpen ProductInfoDialog
2014/11/27:20:20:04 Adam JOHNY PageOpen InventorFlavorSelectionDialog
2014/11/27:20:20:05 Adam JOHNY Inventorui==DefaultLanguage: en-us
2014/11/27:20:20:05 Adam JOHNY Inventorui==InstallName: INVENTOR
2014/11/27:20:20:05 Adam JOHNY Inventorui==ProductName: Autodesk Inventor 2014
2014/11/27:20:20:05 Adam JOHNY Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/11/27:20:20:05 Adam JOHNY Inventorui==DeploymentName:
2014/11/27:20:20:05 Adam JOHNY Inventorui==SetupTitle: Autodesk Inventor 2014
2014/11/27:20:20:05 Adam JOHNY Inventorui==ConfigTransform:
2014/11/27:20:20:05 Adam JOHNY Inventorui==ExeParams:
2014/11/27:20:20:05 Adam JOHNY Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/11/27:20:20:05 Adam JOHNY Inventorui==SupportLink:
2014/11/27:20:20:05 Adam JOHNY Inventorui==InfotainmentLink:
2014/11/27:20:20:05 Adam JOHNY Inventorui==MsiFileName: inventor.msi
2014/11/27:20:20:05 Adam JOHNY Inventorui==AdminImageConfigName: Imgx64
2014/11/27:20:20:05 Adam JOHNY Inventorui==AdminImageRoot:
2014/11/27:20:20:05 Adam JOHNY Inventorui==GetBaseDeploymentName:
2014/11/27:20:20:05 Adam JOHNY Inventorui==DeploymentLocation:
2014/11/27:20:20:05 Adam JOHNY Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/11/27:20:20:05 Adam JOHNY Inventorui==InstallDeploymentShortcut:
2014/11/27:20:20:05 Adam JOHNY Inventorui==ModifyDeploymentShortcut:
2014/11/27:20:20:05 Adam JOHNY Inventorui==SetupLockType: 2
2014/11/27:20:20:05 Adam JOHNY Inventorui==SetupNetworkType: 1
2014/11/27:20:20:05 Adam JOHNY Inventorui==SystemLocale: 1051
2014/11/27:20:20:05 Adam JOHNY Inventorui==EvalMsiFilePath: C:\Users\Adam\AppData\Local\Temp\_AIC6E6.tmp\SetupRes\eval.msi
2014/11/27:20:20:05 Adam JOHNY Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/11/27:20:20:05 Adam JOHNY Inventorui==InstallLogPath: C:\Users\Adam\AppData\Local\Temp\Inventor2014Install.log
2014/11/27:20:20:05 Adam JOHNY Inventorui==ConfigFile: C:\Users\Adam\AppData\Local\Temp\_AIC6E6.tmp\Setup.ini
2014/11/27:20:20:05 Adam JOHNY Inventorui==SetupPath: C:\Users\Adam\AppData\Local\Temp\_AIC6E6.tmp\
2014/11/27:20:20:05 Adam JOHNY Inventorui==NetworkLogPath:
2014/11/27:20:20:05 Adam JOHNY Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/11/27:20:41:13 Adam JOHNY Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/11/27:20:41:13 Adam JOHNY PageOpen ProductSelectionDialog2
2014/11/27:20:42:46 Adam JOHNY PageOpen FullProgressDialog
2014/11/27:20:42:47 Adam JOHNY Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/DIRECT...
2014/11/27:20:42:56 Adam JOHNY Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/DIRECT...
2014/11/27:20:42:56 Adam JOHNY Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/27:20:43:24 Adam JOHNY Install DirectX® Runtime Succeeded
2014/11/27:20:43:25 Adam JOHNY Download Play CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/11/27:20:47:54 Adam JOHNY Download Aborted CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2014/11/27:20:47:54 Adam JOHNY Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/11/27:20:47:55 Adam JOHNY Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
I don´t know what to do. can someone give me any advice. Thanks
1 REPLY 1
TravisNave
in reply to: mudry.adam
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
