Good Day
I have tried mulitiple things to get the network license running on the server. The license contains 13 Autodesk Vault Professional licenses, 3 Inventor, 4 AutoCAD Mechnaical.
Things I have tried.
1. On the server, installed the latest LMtools on the server
2. Turned off IPV6 on the server
3. Changed the LICPATH.LIC file on the server for ADMS to 127.0.0.1 (My vault licenses now work because of this)
4. Created System variables ADSKFLEX_LICENSE_FILE with vale @servername (servername being my server) and FLEXLM_TIMEOUT with time out 1000000
5. Deleted/renamed CAS files for products not getting licenses.
6. Deleted LICPATH.LIC file on workstations to try and get it to reset.
7. Turned off firewall on server.
I still am unable to require a license and get FLEXnet Licensing error:-15,570. Non of my software will start other then vault.
Please help, not sure what else there is I can try?
Best Regards,
Brett Caldeira
Solved by BrettCaldeira. Go to Solution.
