Trying ti install Infrasteucture suite standard onto a winxp sp3 32 bit machine. However, i keep getting errors that the windows installer needs to be upgraded. error numbers that show up are #5979 at first, and then #6097.
The machine is fully patched from microsoft, and I explcitly installed the latest windows installer that I could see on the M website.
tryinbg to get past the error by clicking ok, and the installer just spins endlessly
suggestions are welcome!!
Please follow this solution to re-register your Windows Installer.
If not work, please go to Microsoft to download installer 4.5 and reinstall it.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi Emily.
I tried the fixes you suggested, and at least have different errors now. The first error number is 1719. After I hit OK to get past that error message, the next error is 1635, Failed to run AdskExecuteSequence.
Actually though, all I really want to install o n this machines is the Content Service. It does not show up on the list of "Tools and Utilities" in IDSS - only NL and CADManager Tools appear there.
/next steps?
This problem related to the windows installer, you can find many posts on the Microsoft website.
http://www.regmender.com/how-to-fix-windows-installer-error-1719.html
Please check if any can solve your problem.
