Installation & Licensing
Windows instalation problems
1 REPLY 1
219 Views, 1 Reply
I've troubles with installing maya 2014. I can download everything but after 5 minutes of installing it always say "instalation completed and there were some erros". I see nothing is installed and press on the error logs the last line says: "Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\robin\AppData\Local\Temp\vcredist_x64_2005.log"" " 2014/2/11:18:12:37 robin PC-ROBIN Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603" any solutions ? you can see the log file in the attachement
1 REPLY 1
david.lau
Administrator Productivity
