Installation & Licensing
windows 8.1 no autodesk program installing
2 REPLIES 2
298 Views, 2 Replies
I have been trying to install inventor 2015 on my laptop it has more then the recommended requirements. it keeps failing from what i can tell it  is during the installation of the low res image library im am going to attach the instllation log. Also I have tried installing other versions of inventor and also maya and the same happens. really needs some help any input welcome.
2 REPLIES 2
DannyHubbard
The errors you are getting are around problems downloading files, try downloading using the virtual agent instead.
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
https://screencast.autodesk.com/Main/Details/d271b68b-9d81-40e3-a2ce-b81a1cd97f6f?t=11.083s&autoplay...
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
So yesterday after posting this I tried again and I figured out a way to get it I downloaded and installed autocad 15 first I don't know if the helped any and then I downloaded and installed inventor 15 I am unsure if I had use the download now before bit this time it worked and I was able to use it. Thank you for your input Danny Hubbard.
Administrator Productivity
