Installation & Licensing
Windows 7 - Blue screen when trying to install 3DS Max
3 REPLIES 3
naveenmedia
821 Views, 3 Replies
Since 3DS Max is Windows only, I've partitioned the boot drive on my Mac Pro and have installed Windows 7 64-bit. I'm attempting to install 3DS Max, but the installation crashes the OS when trying to install Direct X (step 11 of 20, I believe). I get the blue screen of death.
Is there a workaround for this? Can I install Direct X myself (or at least try), and will the 3DS Max installer skip this step?
Help. The only reason I went to all the trouble of installing Windows on my system was for 3DS Max.
3 REPLIES 3
TravisNave
in reply to: naveenmedia
Yes, you can update DirectX on your own and the installer will skip the step.  However, there is no way to modify the installation to skip this step.  Make sure you have the latest DX11 files on the machine first.  Also, post the BSOD error here next time as it might be something else, like video driver or similar...
Autodesk Forums:
naveenmedia
in reply to: TravisNave
OK, thanks, will do!
DarrenP
you need to try to figure what caused the blue screens
it may be a piece of hardware that is failing
DarrenP
Administrator Productivity
