Installation & Licensing
WHY MUST AutoCAD install .NET?????????????????
3 REPLIES 3
554 Views, 3 Replies
2012/11/22:12:23:26                Installing .NET Framework Runtime 4.0 Language Pack: G:\Software\autocad 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2012/11/22:12:23:34                Install        .NET Framework Runtime 4.0 Language Pack        Failed        Installation aborted, Result=1603
Why!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
RESOLVE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
DRIVE ME CRAZY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Edited by
Discussion_Admin
3 REPLIES 3
TravisNave
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Edited by
Discussion_Admin
Autodesk Forums:
in reply to: TravisNave
I HAVE DONE EVERTHING I CAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
STILL CANNOT INSTALL IT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
WHAT STUPID SOFTWARE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
TravisNave
Relax.  The software is fine.  It's your operating system that has the problem.  Why don't you try to install the full version of .NET Framework manually from Microsoft and see if you can get it to install first.
Autodesk Forums:
Administrator Productivity
