Installation & Licensing
Member
wongbean
Message 1 of 4 (341 Views)
WHY MUST AutoCAD install .NET?????????????????
341 Views, 3 Replies
11-29-2012 04:18 PM
2012/11/22:12:23:26                Installing .NET Framework Runtime 4.0 Language Pack: G:\Software\autocad 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2012/11/22:12:23:34                Install        .NET Framework Runtime 4.0 Language Pack        Failed        Installation aborted, Result=1603
Why!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
RESOLVE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
DRIVE ME CRAZY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Edited by
Discussion_Admin
TravisNave
Message 2 of 4 (319 Views)
Re: WHY MUST AutoCAD install .NET?????????????????
11-30-2012 08:23 AM in reply to: wongbean
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Edited by
Discussion_Admin
Member
wongbean
Message 3 of 4 (296 Views)
12-01-2012 08:55 PM in reply to: TravisNave
I HAVE DONE EVERTHING I CAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
STILL CANNOT INSTALL IT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
WHAT STUPID SOFTWARE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
TravisNave
Message 4 of 4 (269 Views)
12-03-2012 01:58 PM in reply to: wongbean
Relax.  The software is fine.  It's your operating system that has the problem.  Why don't you try to install the full version of .NET Framework manually from Microsoft and see if you can get it to install first.
