Hello, Because there aren't enough disc space in my c:/ drive ı tried to install revit on d:/ drive.However it gives error that I need 52,8GB free space in my c:/ drive.However Revit doesn't take so much space.I tried to change my default installation path from c:/ to d:/ by following these steps:
run/regedit/HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion and changing the value to d:/
Now ı can install any software except revit on my d:/ drive.however revit again gives same error that I need 52GB free space in my C:/ drive.Is there a way to solve the problem?Thank you
Check out this previous post, it should help you out.
Danny
You may be able to make some system changes that will allow you to install your Autodesk product and avoid this error. Please review my KB article for more information:
http://forums.autodesk.com/t5/Installation-Licensing/Out-of-disk-space-during-installation-to-anothe...
Good Luck!
