Where is the activation code for autocad2014 student? The activation code on my account does not consist of enougth numbers and does not work. Please Help! How to you contact anyone from autodesk?
Solved by franner16. Go to Solution.
Solved by kvork. Go to Solution.
Solved by JDMather. Go to Solution.
The bug appears when you first start the program and try to activate it. Your link was not helpful. Indicates a problem with "Email Associated with the Serial Number".
@camilo.lemosHi, I've been trying to activate my revit 2015. But it has been giving me errors. my serial number is 900-82999*** (blanked for personal purposes), product key 829G1 and the request code is: 6UN9 8ZY1 ZSVL W2VH PQ0S 7NLY J723 HGLZ. If you could give me an answer that would be very brilliant. Thank you
Welcome to the community...
To the right of your posting is a link New: Get an Activation Code. To see that information you have to come back to the forums. Good luck and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
hello hello, please i need your help, when i activate robot structural 2017 they ask me for an activation code.
i download robot 2016 instead but i need robot 2017 because i am working with many programs 2017 like revit, advance steel, etc.
could you help me please
I have been trying to install Autocad 2015 student version but it does not activate itself automatically, even when I try to activate it manually transition can not be completed.
You need to provide more info (but don't share personal info like your serial #) like a screen shot showing what you are faced with.
Mark Lancaster
I don't know how much more I can be clear. I downloaded autocad2015 educational version. Installation is done, but when I launched program, naturally it is dictated to activate the program. When I press the activate button it does not activate and gives error 400. Please help me
Thanks for the 400 error info. You have to understand there are different activation issues/error codes and I have no clue what you are seeing.
Have you tried this link: New: Get an Activation Code
Mark Lancaster
I did but I dont even see LET'S START PAGE when I launch the program. Also I try to get activation code by online but it is stated that system has encountered with a a failure and transition can not be completed. I try every version of autocad last two days by installing educational versions but I could not manage to get it done.
The LETS GET STARTED dialog is only for the 2017/2018 product line.
Your should've gotten a prompt to run in trial or activate it. Is the product running or not?
Mark Lancaster
The prompt is seen and I pressed the ''activate'' button the product is running but since it is not activated it is closing automatically.
What happens if you select to run it in trial mode? Does the application start?
Mark Lancaster
:Launch the application.. Take a screen shot of what you are seeing about activation and provide here. Don't select any buttons or continue.. Also make sure none of your images contain your serial # and if they do, blur the serial # out. At this point you should be seeing an option to run in trial or activate so I need to see what you are actually seeing.
Mark Lancaster
Just to confirm.. You said nothing else appears when you select the activate button, is that correct? If nothing is appearing it either sounds like something on your machine is blocking the activation process or you have a corrupt installation.
I would at this point, perform a clean uninstall per these instructions. Just make sure to adjust settings if you have other Autodesk products already installed/working on your machine. Then,
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
Mark Lancaster
Welcome to the Autodesk User's Community..
This is a user community we don't issue activation codes, they come from Autodesk. Even if we could, how in the world do we know what Autodesk product and version you have. Also are you a student?
Mark Lancaster
My reply was not directed at you and you can disregard my information.. However if you are watching or posted in this given discussion you will get a reply whenever someone else replies.
Mark Lancaster
