Installation & Licensing
Valued Contributor
1 Kudo
Post 1 of 2
where are stored the environment settings ?
181 Views, 1 Replies
11-28-2012 08:02 AM
By environment settings I mean things that are NOT in the cuix.
For exemple:
-position, size of properties, design center and tool palette.
-view settings inside the toolpalettes
-the fact that all locations are locked
All of this is to ease a big deployment (80+ people)
I already found many settings in the registry (HKEY_CURRENT_USER\Software\Autodesk\AutoCAD LT\R18\ACADLT-B001:409\Profiles) and extracted them...
But it's not working for the a.m. settings.
Product Support
99 Kudos
Post 2 of 2
Re: where are stored the environment settings ?
12-03-2012 03:56 PM in reply to: c.dufrene
This depends on the product but typicaly the settings are located in both the registry and in folders in the user profile. Here is an example
AutoCAD 2013:
Reg Keys - HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0
Folders -
C:\Users\%username%\AppData\Local\Autodesk\AutoCAD 2013
C:\Users\%username%\AppData\Roaming\Autodesk\AutoCAD 2013
Jeffry Asbury
