Installation & Licensing
What is the WIndows XP command line installation procedure for AutoCAD 2013?
1 REPLY 1
wegroves
433 Views, 1 Reply
AutoCAD 2013 will not install for me on a LenovoT430si laptop runninng WIndows XP Pro. The regular Auodesk Install procedure goes most of the way, but then a Windows Installer display opens giving information about msiexec options, but there is only an OK button on this display. When I try the installation using the command line and msiexec /i, I am not entering the correct sequence to allow the installation from the USB drive, e.g. msiexec /i G:\x86\acad\acad.msi.  I also would like to install Inventor and Revit on this same laptop. Can anyone tell me how to accomplish the installation of these Autodesk 2013 packages?
1 REPLY 1
TravisNave
in reply to: wegroves
You might have a problem either with the download package or with your MSI Installer.  You might try upgrading the MSIExec and then redownloading the Autodesk installer.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
