Installation & Licensing
What is the product code (registry) of Autodesk Revit 2013?
3 REPLIES 3
767 Views, 3 Replies
I am trying to run Microsoft Fix It to uninstall a partially installed Autodesk Revit. I need to know th product code to do so. What is the product code (registry) of Autodesk Revit 2013?
Tags (2)
3 REPLIES 3
antonio140584
Same problem here. Have you solved? I somehow failed to install Revit 2013 and now it doesn't start, it doesn't uninstall and it's not possible to install a new one becouse the system said it's already installed. Tried Fix-it from Microsoft: the first time it said it solved the problem, but it didn't. A second time, Revit is no longer on Fix-it list and to make the program work I have to enter the "product code", which after long research I can't find. Any help?
ukdxb012
in reply to: antonio140584
Hi, hopefully this link will help you both out 🙂
http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
antonio140584
in reply to: ukdxb012
Many thanks Duncan, it worked for me.
Just to know: it took ages to complete the installation (around 5h with a 2Mbit connection), remaining completely still close to the end, when it prompted the "prepare Revit content" message. But in the end the downloading and installation progress continued.
I gave you "Kudos" but can't see any "Accept as Solution" button(s) below.
Administrator Productivity
