Hi Guys,
I’m trying to deploy AutoCAD 2015 to my DT Department and have no luck with the network deployment method. AutoCAD will not run on the computers its allocated but if i do a manual installation it works fine.
Anyway, i have used the Sample Batch Files method and it installs fine and the software runs as it should but i keep getting the online activation message/30 day trial thing.
This there anyway around this so it can be activated on install or pre-activated?
You may have better luck over in the Installation & Licensing forum;
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
You might be making your deployment incorrectly. Also, are these stand-alone activations? And have you activated them with admin rights?
Sorry for the delay, Did not know there was a replay.
Im asuming that the batch is just for standalone activation unless the ACADSTANDALONENETWORKTYPE= is changed
The deployment seems to be fine by batch but when I do a deployment though the software AutoCAD does not even start, it just crashes.
The batch way is the only that works (so far) for installing the software.
We plan to install it on 50 workstaions but don't really fancy manually activating 50 workstaions.
Here is my batch is it helps:
setup.exe /t /qb /language en-us /c ACAD: INSTALLDIR="%programFiles%\Autodesk\AutoCAD 2015" ACADSERIALPREFIX=XXX ACADSERIALNUMBER=XXXXXXXX ADLM_PRODKEY=XXXX ADLM_EULA_COUNTRY=US InstallLevel=5 ACADSTANDALONENETWORKTYPE="1"
The XXX are my keys removed
So im gessing that this will not auto activating it but installs the key? or is there a way of setting the batch to activate them
