Installation & Licensing
Virtual Hosting of FlexLM / LMTOOLS
4 REPLIES 4
6417 Views, 4 Replies
I see in the documentation for Map 3D 2013 that the only "Virtual Machine Support" shown is for "VMware ESX 3.5" on "Intel PC 64".  Does this mean Autodesk does NOT support Microsoft Hyper-V on Windows Server 2008 R2 ?  Just making sure before we build a new license server for our environment.  The virtualization platform at this client is Hyper-V only.
4 REPLIES 4
TravisNave
The NLM will run fine on a virtual machine.  Just make sure you hard code the MAC address as virtual machines have a tendency to change for no good reason, thus invalidating your license file.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
I figured as much.  I don't doubt it would run reliably, but I have to verify if it is officially "supported" by Autodesk.  The customer I am working for insists it is vendor supported.
TravisNave
It is officially supported by Flexera, the publisher of the license manager.  Autodesk simply licenses the technology, along with many other 3rd party vendors.
Check out Chapter 15 of the user guide:
http://www.globes.com/support/utilities/fnp_LicAdmin_11_10_1.pdf
Autodesk Forums:
Thank you!  I appreciate the help.
Administrator Productivity
