Installation & Licensing
Vehicle Tracking 2015 installation with Factory Design Suite 2015
3 REPLIES 3
Lancashirehomes
304 Views, 3 Replies
I am having trouble with my installation of Vehicle Tracking with my Factory Design Suite. According to the readme, once installed, the software should be accessable on:
  • Autodesk® AutoCAD®
  • Autodesk® AutoCAD®Architecture
  • Autodesk® AutoCAD® Civil 3D®
  • Autodesk® AutoCAD®Map 3D
  • Autodesk® AutoCAD®Plant 3D
  • Autodesk® AutoCAD® Utility Design
However, while the software is avalible on my Architecture and works fine, it has not installed onto the bog standard AutoCAD. I have tried CUILOAD to side load the ribbon from C:\Users\<user>\AppData\Roaming\Autodesk\Vehicle Tracking\Menus\atra200.cuix which installs the ribbon menu, but none of the buttons work on it.
The readme also mentions this.
To enable Autodesk Vehicle Tracking in supported host applications that are installed after Autodesk Vehicle Tracking:
  1. Close all versions of AutoCAD and AutoCAD-based applications that are currently running.
  2. Insert the Autodesk Vehicle Tracking media into your computer's media drive.
  3. Locate the following file:
    • For 32-bit operating systems, locate Autodesk Vehicle Tracking 2015_32.exe in the x86\AVT_CMD_REG folder.
    • For 64-bit operating systems, locate Autodesk Vehicle Tracking 2015_64.exe in the x64\AVT_CMD_REG folder.
  4. Double-click the file and follow the on-screen instructions.
However when doing this I get a popup box to install to Architecture, not not to normal AutoCAD.
This is frustrating because it installed without a hitch on Architecture. Could the issue be that I have AutoCAD Mechanical installed that comes with FDS?
Help would be appriciated.
Nathan
3 REPLIES 3
DarrenP
in reply to: Lancashirehomes
yes probably since autocad mechanical is not a supported host application for Vehicle Tracking
DarrenP
Lancashirehomes
in reply to: DarrenP
Does that mean the AutoCAD I run is not "stand alone" and runs inside some kind of Mechanical framework? It's a simple acad.exe and not the acadm.exe for Mechanical.
jas25t
Having a similar issue with Product Design Suite 2015, which is a real issue considering there is not any of the compatible versions of AutoCAD available, even though it is shown that it is included online
http://www.autodesk.com.au/suites/product-design-suite/included-software
Intel Core i7-4790K CPU @ 4.00GHz
32 GB RAM
NVIDIA Quadro K2200
Administrator Productivity
