I upgraded to a 64 bit computer. After reinstalling vault I get the error when logging in autodesk vault 2011 is not compatible with the "server name" hosting the following server applications. Vault Server version 15.2.66.0, Vault workgroup server version 15.2.66.0, vault collaboration server version 15.2.66.0
Solved by DarrenP. Go to Solution.
what client are you using vault workgroup or vault collaboration?
you can't mix them with each other
DarrenP
your welcome
DarrenP
