Installation fails with the dialog "Error 997, Operlapped I/O operations is in progress"
Windows 8.1 - nothing all that interesting about the system.
Here's the log:
2014/10/21:10:45:04 sgmiller SAM-XPS15 === Setup started on SAM-XPS15 by sgmiller ===
2014/10/21:10:45:04 sgmiller SAM-XPS15 Path_Length: 154
2014/10/21:10:45:04 sgmiller SAM-XPS15 Current Directory C:\Users\sgmiller\AppData\Local\Temp\_AIB4B3.tmp
2014/10/21:10:45:04 sgmiller SAM-XPS15 Launch
2014/10/21:10:45:05 sgmiller SAM-XPS15 PageOpen LaunchDialog
2014/10/21:10:45:08 sgmiller SAM-XPS15 PageOpen LicenseDialog
2014/10/21:10:45:12 sgmiller SAM-XPS15 PageOpen ProductSelectionDialog2
2014/10/21:10:45:20 sgmiller SAM-XPS15 PageOpen LicenseDialog
2014/10/21:10:45:21 sgmiller SAM-XPS15 PageOpen LaunchDialog
2014/10/21:10:45:24 sgmiller SAM-XPS15 PageOpen LicenseDialog
2014/10/21:10:45:27 sgmiller SAM-XPS15 PageOpen ProductInfoDialog
2014/10/21:10:45:28 sgmiller SAM-XPS15 PageOpen ProductSelectionDialog2
2014/10/21:10:46:21 sgmiller SAM-XPS15 PageOpen FullProgressDialog
2014/10/21:10:46:21 sgmiller SAM-XPS15 Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_VPC2015_ENU_32-64bit_R1_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/10/21:10:46:22 sgmiller SAM-XPS15 Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/10/21:10:46:22 sgmiller SAM-XPS15 Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_VPC2015_ENU_32-64bit_R1_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/10/21:10:46:23 sgmiller SAM-XPS15 Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/10/21:10:46:23 sgmiller SAM-XPS15 Installing DirectX® Runtime: "C:\Autodesk\Autodesk_VPC2015_ENU_32-64bit_R1_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/21:10:46:26 sgmiller SAM-XPS15 Install DirectX® Runtime Succeeded
2014/10/21:10:46:26 sgmiller SAM-XPS15 Installing Microsoft Report Viewer Redistributable 2012: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Vault Professional 2015 (Client)" SETUP_PACKAGECODE={83AE12DA-1900-0003-0000-611B8E852FB3} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_VPC2015_ENU_32-64bit_R1_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/21:10:46:27 sgmiller SAM-XPS15 Install Microsoft Report Viewer Redistributable 2012 Succeeded
2014/10/21:10:46:27 sgmiller SAM-XPS15 Installing Microsoft Report Viewer Redistributable 2012: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Vault Professional 2015 (Client)" SETUP_PACKAGECODE={83AE12DA-1900-0003-0000-611B8E852FB3} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{F1949145-EB64-4DE7-9D81-E6D27937146C},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_VPC2015_ENU_32-64bit_R1_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/21:10:46:31 sgmiller SAM-XPS15 Install Microsoft Report Viewer Redistributable 2012 Succeeded
2014/10/21:10:46:31 sgmiller SAM-XPS15 Installing Autodesk® Vault Professional 2015 (Client): TRANSFORMS="C:\Autodesk\Autodesk_VPC2015_ENU_32-64bit_R1_dlm\x64\en-us\VP\VaultPro.mst;C:\Users\sgmiller\AppData\Local\Temp\_AIB4B3.tmp\x64\VP\VaultPro-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_VPC2015_ENU_32-64bit_R1_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Vault Professional 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/21:10:47:19 sgmiller SAM-XPS15 Install Autodesk® Vault Professional 2015 (Client) Failed Installation aborted, Result=1603
2014/10/21:10:47:27 sgmiller SAM-XPS15 Rollback Microsoft Report Viewer Redistributable 2012 Succeeded
2014/10/21:10:47:27 sgmiller SAM-XPS15 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/10/21:10:47:28 sgmiller SAM-XPS15 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/10/21:10:47:28 sgmiller SAM-XPS15 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
That error could be due to a Windows profile issue. I suggest:
Also stop the backburner service if it was installed from the Autodesk suite previously.
The computer is not part of a domain or workgroup. There is only one user on the machine.
Verified that there was no "Backburner" service listed in the services control panel.
Ran "run as administrator" on Setup.exe
Still has the same problem.
Can someone confirm that Vault 2015 has been tested with Windows 8.1 after an Inventor installation?
Yes. It works with 8.1.
I am having this same problem with the installation of Autodesk 3Ds. Any help on resolving this would be greatly appreciated.
