Installation & Licensing
kkhofner
258 Views, 1 Reply
vault 2014 install error
I am installing vault 2014 in server 2008 r2 and I have recieved error 29001. Vault Management error: Client not found response content of ", but expected'text/xml'. the request failed with an empty response (see attachement). I have tried looking it up online but I cant find anything about it. any ideas how to fix this?
Thanks!
1 REPLY 1
TravisNave
in reply to: kkhofner
In the past, Vault 29001 errors have generally been related to the registration of the correction version of ASP.NET to IIS.  I always registered it manually from the version of .NET installed.  For example:
C:\Windows\Microsoft.NET\Framework\v2.0.50727>aspnet_regiis.exe -i
 Here's a good place to start:
http://crackingthevault.typepad.com/crackingthevault/2010/10/error-29001-vault-management-error.html
Make sure you have installed IIS and .NET, of course.  Good Luck!
Autodesk Forums:
Administrator Productivity
