Hi all, first post so please be gentle.
I've been tasked with installng and configuring Vault for use with Inventor at first. Now I've done some reading and remain confused but I'm hoping that will change soon.
We have access to Vault 2014 Pro and all of the previous releases and the project will be modelled using Inventor 2012. My first question is are the two compatible or will I need to install Vault 2012?
heading back to my reading and research now....
Thanks in advance.
Solved by JoAnn_Hogan. Go to Solution.
No need to change to Vault 2012. Inventor 2012 would be able to connect to Vault 2014
I would stongly recommend that you get your closet VAR to do the implementation for you as they have to customize and set it up according to your needs. They will also test to make sure everything works and transfer your data for you.
And here is the getting started guide as well: http://knowledge.autodesk.com/support/vault-products/getting-started#?rows=10&sort=score
Glad I could help a little bit. Good luck with this
Yes, SQL is included but it is the express version 2008. When you the ADMS it will automatically install SQL express for you.
Fantastic, we have progress. I have Vault installed, EDMS working, Client working, not I need to get some files in there and configure the applications. Very much appreciate the help
Glad it is working now and I could be of help.
