Installation & Licensing
Active Member
dtobitt
Message 1 of 6 (1,150 Views)
Valid License not be obtained (0.0.0) check out failed error 20 3ds Max
1150 Views, 5 Replies
07-06-2011 09:36 AM
Would be grateful if anyone could help, I haven't managed to find a solution that works in my case yet. Trying to install 3ds Max 2012.   Is there a simple answer that I've missed as to why I can't load the program. The LMTools program was installed straight on the server. I used the Host Name and the Physical Address for the the Host ID to get the license file from Autodesk as per the instructions and put it on the c:\ of the server .  All computers can ping each other.  Server is Small Business Server 2008, client computers are XP and Windows 7.  Any help much appreciated. Diagnostic files attached from LMTools and Host ID (the times are an hour out on here too) Thanks
Its ok it's sorted, the licence was for an upgraded version rather than the one I requested.
DarrenP
Message 2 of 6 (1,146 Views)
Re: Valid License not be obtained (0.0.0) check out failed error 20 3ds Max
07-06-2011 09:41 AM in reply to: dtobitt
its most likely a IPV6 issue try using this license manager: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10976858&linkID=13140816
Active Member
dtobitt
Message 3 of 6 (1,133 Views)
07-07-2011 01:32 AM in reply to: DarrenP
No sorry that doesn't work, any other ideas?
Active Member
dtobitt
Message 4 of 6 (1,128 Views)
07-07-2011 03:08 AM in reply to: dtobitt
Member
john
Message 5 of 6 (1,115 Views)
07-07-2011 09:16 AM in reply to: dtobitt
Having the same issue. We have several licenses of 3DSmax, 3DSmax ECSP, and one license of Maya ECSP. On my system, 3DSmax 2012 is the only program that fails to obtain a license....the remaining suite of products (mudbox, XSI, motionbuilder) all open fine.
I have tried renaming the Cascadeinfo.cas file, and restarting 3DSmax, but I am still throwing the same error. Our license manager is running fine, and our .lic files are up to date with our subscription products. Assistance please.
TravisNave
Message 6 of 6 (1,106 Views)
07-07-2011 09:32 AM in reply to: john
John, what is the error that you receive?  Also, is there anything listed in the debug.log file as to why the license is being denied?
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
