Installation & Licensing
Valid License could not be obtained
1 REPLY 1
EldonRohlena7778
680 Views, 1 Reply
I recently moved the license server to a different computer.  I have no problem getting the license from other client workstations.  However, I cannot run Inventor from the computer that is running the license server.  I get the following error "Valid license could not be obtained by the network license manager" Error [-15.570].  We were previously running the license server and application from the same computer.
1 REPLY 1
If your OS is Vista or Windows 7 and using IPv6 then this is likely the issue.  You need to make a hosts file change so that your localhost is pointing to an IPv4 like 127.0.0.1 instead of :1.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
