Try extending the FLEXLM_TIMEOUT variable using the following steps. I have
run into this also and it fixed the problem.
1.. Right-click My Computer. Click Properties.
2.. In the System Properties dialog box, click the Advanced tab.
3.. On the Advanced tab, click Environment Variables.
4.. In the Environment Variables dialog box, under System Variables, click
New.
5.. In the New User Variable dialog box, enter FLEXLM_TIMEOUT for the name
and 1000000 for the value.
6.. Click OK to close each dialog box.
7.. Launch the Autodesk application.
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=7574782&format=print&linkID=9240617
Tracy Ostby
Marvin Windows and Doors
CAD Systems Administrator
tostby@marvin.com
www.marvin.com
wrote in message news:5884217@discussion.autodesk.com...
The code is Error[1.5-18].I am using autocad 2008.Other software that using
lmtools is working fine but not autocad 2008.We have remove services and
setup the flexlm services 1 again. Force stop and start the server
again.But it is same.
Note:We are using server window 2000.
Please advice.
