When I installed Revit Structure 2012, the only template installed is the US Imperial units template, and I am familiar with the metric units. I tried to change the default template but discovered that the metric template was not installed. How do I get the metric unit template installed?
Hi:
You may want to check on this link: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14973721. You may download the metric units and install it on your machine.
Thank you and have a nice day!
Please click on "Accept as Solution" if this suggestion helped you solve your request.
