I can't deploy 3ds max 2014 via Group Policy Objects (GPOs). I red http://download.autodesk.com/us/industries/mne/pdf/2013/Autodesk_ME_NetworkAdminGuide_enu.pdf and I tried to follow page 16 instructions.
I got this error in the Windows 7 Application Event Log:
"Product: Autodesk 3ds Max 2014 -- 1: 5 2: adlmPITSetProductInformation failed. 3: 26"
I tried to install manually the same custom deployment from the distribution share point, no problemo. the install runs fine. This is not a network or custom doployment problem. Certainly the GPO configuration...
I tried --> http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13540825&linkID=9241177
to remove manually ProductInformation.pit on my rendernode and run "gpupdate /force" to relaunch the install process. but I got the same error --> "Product: Autodesk 3ds Max 2014 -- 1: 5 2: adlmPITSetProductInformation failed. 3: 26"
What can I do ? I'm blind, I only got the message from Application Event Log which is not really verbose....
We are deploying 3dsmax 2014 SP2 on windows 7 pro SP1
thx
