Installation & Licensing
Use 2007 with lic file of 2011 NLM
5 REPLIES 5
mkaandorp
429 Views, 5 Replies
We have .lic file for AutoCAD MAP 2011 and subscription. We want to use 2007 in some cases. Is this possible with the same .lic file?
5 REPLIES 5
TravisNave
in reply to: mkaandorp
Yes, if you have your original 2007 license file that was not part of a PACKAGE Subscription.
Autodesk Forums:
mkaandorp
OK, what I will do:
I make one .LIC file including:
1 PACKAGE+INCREMENT part for 12 NLM 2011
1 PACKAGE+INCREMENT part for 5 NLM 2011 (we have 2 NLM package 12+5 for 2011)
1 INCREMENT part for 12 NLM 2007 (we have 1 NLM 12 for 2007)
Will this work?
Marco
Yes. (if package are created the same day)
Franck Hervet Edited by: frhervet on May 6, 2010 12:36 PM
TravisNave
Franck is right. Your 2011 has to be created on the same day. And you only need one of the PACKAGE codes. Just copy both INCREMENTS. Append your 2007 and you will be set.
Autodesk Forums:
mkaandorp
Thanks for the reply.
I have change the lic file and it works OK.
1x PACKAGE 2011
2x INCREMENT 2011
1x INCREMENT 2007
Marco
Administrator Productivity
