Dear Team,
I will like to know if it is possible to upgrade from Autodesk Building design suite premium to Building design suite Ultimate?
If possible, what is the procedure?
Thank you.
Solved by DarrenP. Go to Solution.
yes you can
you need to confirm with your reseller on the procedure
http://www.autodesk.com/resellers/locate-a-reseller?cntr=US
DarrenP
