Installation & Licensing
Uninstalling old 3ds Max versions
1 REPLY 1
thomas-gw-konjak
644 Views, 1 Reply
Hello everyone!
I have to clean up my partition a bit, so I was thinking about uninstalling every 3ds Max programm (e.g. fbx plugin, material library, etc.) that is NOT the latest version. Does that in any way affect the use of 3ds Max 2014 ? E.g. that some functions won't work or some library  is missing?
I know e.g. Autodesk FBX Plug-in 2013.1 is the latest (at least for me) version, so ofc I will keep it.
Thanks in advance for all the help,
Greetings,
Thomas.
1 REPLY 1
Welcome to the community.
Autodesk installations are separate, so uninstalling old versions should not affect other ones at all.  You should be able to safely free up some space.
Good Luck!
Autodesk Forums:
Administrator Productivity
