I have the 2011 Entertainment Suite on my computer. Unfortunately my computer is shutting down during startup and randomly during usage. Hence I may have to reinstall my OS and programs, possibly to a new hard drive. Can I simply uninstall the Entertainment Pac via the Control Panel and then reinstall. In my Adobe apps, I had to deactivate them. Is there some type of deactivation process? Any help would be appreciated.
David
Solved by dvedve. Go to Solution.
Solved by hashim.mundol. Go to Solution.
If you wish to avoid re-activating the Product on the new OS. Please use the License Export Utility to export the license. Then import into the new OS.
