i uninstalled my autocad improperly a while back and now that i tried to install it again it says that autocad mechanical is still installed on my pc. i tried searching for the autocad mechanical files all over my pc, i even tried restoring it to an earlier time but that didnt help either. i tried to run the installation through but since it says its already installed on my pc all i can install is the inventor fusion.
does anyone know how i can solve this problem without having to completely reinstall my system?
Autodesk recommended uninstall and reinstall procedures:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617
Also use a quality registry cleaner like CCLEANER (freeware version works fine too).
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
