We have a large base of Autodesk products installed. In 2013, we used uninstall tool (C:\Program Files\Autodesk\Uninstall Tool 2013\InvCleanup.exe) to uninstall products in silent mode by a send to workstations a dos command like
"C:\Program Files\Autodesk\Uninstall Tool 2013\InvCleanup.exe" /qn
It wasn't a conventional method but it worked perfectly with a fast and simple uninstall.
In 2014 Uninstalltool.exe seems to be changed and I don't find solution to run it in silent mode with some arguements in dos or another way
Have you some correct arguments or other method to run uninstalltool.exe in silent mode ?
The uninstall batch file is found in the SMS_SCCM scripts folder of the deployment.
For deployment user, you can find a script folder under deployment Admin image folder, named "SMS_SCCM scripts", there is txt files named like #deploymentName#_Uninstall.txt to uninstall products which installed from the deployment. How to turn the txt file into BAT file to run, you can follow the instruction in "Product_Uninstall_ReadMe.txt" (Which is attached)
For Uninstall Tool, there is no silent command yet.
Arron
Would it be possible for someone to attach the pdsu_2013_64_uninstall.txt and the same file for vault 2013 as well? I cannot locate these files on our companies deployment servers.
