I installed Autodesk AutoCAD 2015 onto my laptop today but every time it eventually loads, I get this error message.
'Fatal Error: Unhandled Access Violation Reading 0xffffffff Exception at f4060004h'
Any ideas what this could mean? Thanks in advance for your help.
In my experience, this issue is usually caused either by a malware infection or a problem with the .NET Framework.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
I've recently used the clean-up tool and reinstalled .NET framework 4.5.1, and still get the same error. I've posted on a windows 7 forum about the same issue, so thought I'd link it here to pool the information.
Any other ideas? Don't think I have a malware issue. I've been using Bullguard Antivirus for a few years and think my laptop is clean.
Thanks for your help 🙂
Do you have any devices connected to your computer? Odd network devices? Etc.?
Also, it could be video card related. What is your video card and driver version? If your laptop also has an onboard Intel/generic card in addition to a 3D card, this could also be a problem. Disable it in BIOS.
First of all do a clean install of this certified driver:
http://www.nvidia.com/download/driverResults.aspx/81879/en-us
Then go into your BIOS (probably like F2 at boot or something) and see if you have a setting to disable it. On the Dell laptops, this was called Optimus. You can see a link to this process in my signature.
Hope that helps.
In your case, Optimus will be the right choice.
So yeah, just do a clean install. Hope it helps!
Not explicitly, how would I get it to do that?
*EDIT*
I used Nvidia Control Panel to force AutoCAD to run with the 'High-performance NVIDIA Processor' but I still get the error.
I'm not sure if this is normal or not, but on the 'global settings' tab, the preferred graphics processor is locked to 'Integrated Graphics' and I can't change it.
There's got to be some way to force AutoCAD to use your nVidia card. You might need to find out in the instruction manual of your computer. I have seen some computers have a override button for this. Yours might have some sort of setting for this.
All methods of forcing AutoCAD to use my graphics card seem to be greyed out, as in my attached image.
I have also undertaken a complete clean install of all AutoDesk products as outlined on the support section of this website, but still get the same issue.
i was getting the same error message. i just ran a "repair" in the UNINSTALL program. this fixed my issue.
