Installation & Licensing
Active Contributor
0 Kudos
Post 1 of 10
Unable to Uninstall Autodesk Revit Architecture 2014
4288 Views, 9 Replies
08-16-2013 05:27 PM
I am trying to install Autodesk Revit Architecture 2014 but it tells me that it is already installed. I had a previous installation removed but apparently it was not removed entirely. I tried using the Autodesk Uninstall tool to removed it but that also failed. I have attached a print screen with the view that is shows when it fails.
Does anyone know of a tool that can be used to removed it so I can reinstall the products?
daley1234,
Hello. You could delete these two registry keys. These are the main Revit Architecture keys that would cause your issue:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\0A4B643700410110000007C5D0680240
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\0A4B643700411110409007C5D0680240
Thank you for taking part in our community!
Employee
62 Kudos
Post 2 of 10
Re: Unable to Uninstall Autodesk Revit Architecture 2014
08-19-2013 05:07 AM in reply to: daley1234
You should be able to remove the product using the Microsoft Fix It utility.
http://support.microsoft.com/mats/Program_Install_and_Uninstall
Danny
Danny Hubbard
QA Analyst
Active Contributor
0 Kudos
Post 3 of 10
08-31-2013 07:51 PM in reply to: daley1234
I tried the tool but it did not find Revit installed. I have check just about every registry key that has revit on them and deleted them however, the installer is still telling me that revit is installed.
I do not know what else to do.
1,593 Kudos
Post 4 of 10
09-01-2013 06:06 AM in reply to: daley1234
Did you manually delete The program folders too?
What if you just accept the findings and continue with the Ibstallation, then follow it with a full "repair" reinstall?
Try using a registry cleaner first, then restart Windows after the cleaner stops findings issues. I like CCLEANER myself but there are others.out there.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
0 Kudos
Post 5 of 10
09-01-2013 06:33 PM in reply to: pendean
The installation cannot go any further, its either back or cancel. The
program is not on the machine so it cannot be repaired.
897 Kudos
Post 6 of 10
09-03-2013 07:40 AM in reply to: daley1234
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
I have not tested the MSICUU2.exe on Windows 8 yet.  Could be disasterous...
Product Support
69 Kudos
Post 7 of 10
09-03-2013 11:04 AM in reply to: daley1234
daley1234,
David Dembkoski
Active Contributor
0 Kudos
Post 8 of 10
09-03-2013 03:57 PM in reply to: TravisNave
I installed the tool and ran it but it did not find the software on the machine.
Active Contributor
0 Kudos
Post 9 of 10
09-03-2013 04:10 PM in reply to: dembkod
I deleted the two registry keys and I was able to restart the set-up process. Thanks a million.
Valued Contributor
1 Kudo
Post 10 of 10
01-20-2014 06:41 AM in reply to: dembkod
I had the same issue and deleting the registry keys fixed it for me as well. Took forever to find this post. Thank you!
