Installation & Licensing
Unable to Transfer License for Building Design Suite Ultimate 2012
2 REPLIES 2
387 Views, 2 Replies
I have tried the License Export Utility on the old machine but I get an error message
Export Request Failed. The serial nuimber you entered is not valid.
Error Reference 1
2 REPLIES 2
DarrenP
possibly that serial number was upgraded if it was the license transfer will not work
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-S...
you need to activate manually
You can use the online method to activate your license here:
http://knowledge.autodesk.com/contactus or www.autodesk.com/register
for the contact us page use these steps to fill out a form
1. Activation & Registration
2. Activating a Product
3. Activation Codes & Request Codes
4. I still need help
5. Ask for assistance at the bottom
Or you can can call Autodesk Product Registration and Authorization:
1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and the request code.
DarrenP
in reply to: DarrenP
When I try to use the "Ask for Assistance" the form requires a request code. It suggest to launch the product and the request code will appear at the top of the screen. However when I launch the application it gets stxk on the splash screen with "Checking license..." at the bottom of the screen. Because Request code is a required field I am unable to submit the form.
The other option of calling Autodesk also requires a Request Code that I am unable to get to.
Administrator Productivity
