Installation & Licensing
Member
jeepo84
Message 1 of 5 (1,059 Views)
Unable to start...URGENT!
1059 Views, 4 Replies
10-02-2012 01:52 PM
I have already Autocad LT 2012 installed on my computer and I use it for work (license bought by company where I work). Now I'm about to participate a course in my school (yes...I'm working and studying both at a same time) where AutoCad 2011 is necessary. So, I have requested a student licence and got it. Now when I'm trying to install it I got following error:
Application was unable to start correctly (0xc0000005). Click ok to close the application.
(See attached screenshot)
HELP!!!!!!
Problem solved. Solution was very simple after all. I just renamed the file before started downloading and then it went whitout any further problems.
Thanks for your fast support!
- Jesse -
philip.s
Message 2 of 5 (1,049 Views)
Re: Unable to start...URGENT!
10-02-2012 04:51 PM in reply to: jeepo84
Hi Jesse,
Assuming you already downloaded the software, it looks like using an extraction tool (WinRar) helped others get past the "Application was unable to start correctly (0xc0000005)" error in this thread.
Please accept as a solution if this fully resolves the issue, or reply with additional specifics if the problem persists.
Philip Schmelzer
Member
jeepo84
Message 3 of 5 (1,024 Views)
10-04-2012 03:55 AM in reply to: philip.s
Thanks for support so far. When I extrac it with winrar it gives me errors (see attached image). I have already try to download file several times and with three different browsers ( e.g. internet exblorer complained during download "file could not be verified"....or something like that).
- Jesse -
philip.s
Message 4 of 5 (996 Views)
Re: Application was unable to start correctly (0xc0000005) / CRC Failed in x86
10-04-2012 12:35 PM in reply to: jeepo84
You're welcome Jesse.
So CRC errors are fairly common and I've linked a few of the corresponding solutions from the Autodesk Discussion Forums below.
CRC Error LINK 1
CRC Error LINK 2
Specifically, you might want to try using a an alternate download method and or temporarily disabling all anti-virus software and firewalls.
Philip Schmelzer
Member
jeepo84
Message 5 of 5 (988 Views)
10-05-2012 03:22 AM in reply to: philip.s
- Jesse -
