Installation & Licensing
Unable to start license manager
32 REPLIES 32
Message 1 of 33
estauss
2541 Views, 32 Replies
We are trying to move our 3ds max license from a Win2k3 server to a Win2k8.
I have a new license file from Autodesk and have the network license manager installed on the server and is configured.
However when I try to start the server it fails and when I do a server status I get the following error:
Status
Flexible License Manager status on Fri 7/5/2013 16:03
[Detecting lmgrd processes...]
License server status: @flex2.aero.und.edu
License file(s) on flex2.aero.und.edu: C:\Program Files (x86)\Autodesk Network License Manager\License\3DSMAX7flex2.aero.und.edu.lic:
lmgrd is not running: Cannot connect to license server
 The server (lmgrd) has not been started yet, or
 the wrong port@host or license file is being used, or the
 port or hostname in the license file has been changed.
Server name:   flex2.aero.und.edu
License path:  @flex2.aero.und.edu
FLEXlm error:  -15,570 For further information, refer to the FLEXlm End User Manual, available at "www.macrovision.com".
I have checked and everything is the same as it is on our 2k3 server.
Any help would be appreaciated.
Eric
32 REPLIES 32
Message 21 of 33
estauss
in reply to: TravisNave
Hi Travis,
Not sure what box you are talking about.
Message 22 of 33
DarrenP
in reply to: estauss
its the one on the system settings tab
DarrenP
Message 23 of 33
estauss
in reply to: DarrenP
The box was not checked. I checked the box and rebooted the server...still the same error.
Message 24 of 33
TravisNave
Just to double-check, when you open a CMD prompt and you PING FLEX2.AERO.UND.EDU, what response do you get?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 25 of 33
estauss
I get the valid IPv4 Static IP that we have set for the server
Message 26 of 33
TravisNave
And that is when you PING the server FQDN from itself, correct?
Autodesk Forums:
Message 27 of 33
estauss
correct, or from any other computer in the domain.
Message 28 of 33
DarrenP
its quite possible the license file is corrupt in some way
might need to regenerate a brand new one if none of this works
DarrenP
Message 29 of 33
TravisNave
I sent you a PM.
Autodesk Forums:
Message 30 of 33
TravisNave
I'm at lunch now. Gimme a bit and I'll send you another PM.
Autodesk Forums:
Message 31 of 33
estauss
Sounds good. Thanks
Message 32 of 33
TravisNave
Just to follow up, what we did was put the 64-bit version of the FlexLM on your Server2008 R2 in the 11.7 version.  I have found that for some reason, it just works better on that server.  Good luck with your options file and other license manager vendors.  If you need anything else, just give us a holler.
Autodesk Forums:
Message 33 of 33
estauss
Will do, Thanks for everything Smiley Happy
Administrator Productivity
