We are trying to move our 3ds max license from a Win2k3 server to a Win2k8.
I have a new license file from Autodesk and have the network license manager installed on the server and is configured.
However when I try to start the server it fails and when I do a server status I get the following error:
Status
Flexible License Manager status on Fri 7/5/2013 16:03
[Detecting lmgrd processes...]
License server status: @flex2.aero.und.edu
License file(s) on flex2.aero.und.edu: C:\Program Files (x86)\Autodesk Network License Manager\License\3DSMAX7flex2.aero.und.edu.lic:
lmgrd is not running: Cannot connect to license server
The server (lmgrd) has not been started yet, or
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: flex2.aero.und.edu
License path: @flex2.aero.und.edu
FLEXlm error: -15,570 For further information, refer to the FLEXlm End User Manual, available at "www.macrovision.com".
I have checked and everything is the same as it is on our 2k3 server.
Any help would be appreaciated.
Eric
Solved by TravisNave. Go to Solution.
Make sure your License file matches the hostname and the ethernet MAC address. Then see my IPv6 fix here:
Thanks for the quick response.
I have checked the the license file is correct for the hostname and the mac address. Also, IPV6 is off and has always been off.
IPv6 being off does not prevent the localhost loopback from being ::1. You might PING the server from itself by hostname and verify you are getting a valid IPv4 or 127.0.0.1 response rather than the ::1.
Thanks for the reply.
When I did ping the host name flex2 I got a IPv6 address, when I ping the fully qualified name I get an IPv4 address.
However I changed the host file on the server so that I get an IPv4 address when I ping and it still does not work. the lmgrd will not start, I get the same error:
Status
Flexible License Manager status on Mon 7/8/2013 11:13
When I try to start the server from the Start/Stop/Reread tab it says:
Server Start Faild. The Server May Already Be Running!!
After you have changed the hosts so that both the host and FQDN both ping IPv4, you might need to kill the processes for adskflex.exe and any lmgrd.exe that are running in Task Manager > Processes. Then restart the LMTOOLS service from Start/Stop/Reread.
What is your OS and FlexLM version?
Hi Travis,
Rebooted the server and still get the same error.
Server OS is Win2k8R2 and LMTOOLS is the one that came with the install of 3dsMax 7: Version 9.22.
that maybe why this version of flex lm may not be compatible with server 2008 r2
DarrenP
you can try allowing these ports through your firewall
The FLEXlm® based version uses the following ports:
TCP ports 2080 (for the adskflex vendor daemon)
TCP ports 27000 to 27009 (for the lmgrd master daemon)
DarrenP
you can try starting from scratch by removing the service and setting it up again
before setting it up again make sure the lmgrd and the adskflex.exe are not running in the background via task manager also check the windows services to make sure the flex lm service isn't running
DarrenP
Tried that, and its still not working. giving me the same error.
I have even tried uninstalling everything, with no luck
I was thinking this old program uses the sgiawd.exe vendor daemon file. Is that correct? You might need to add this file to the other .exe files on your NLM...
<attached is a zipped copy of sgiawd.exe>
Hi Travis,
Not sure if that requires that or not. but I downloaded it and put it in the same folder that contains the lmgd, adskflex, lmutil, etc...and rebooted the server and still no luck.
You unzipped it right? Can you copy/paste the header part of your license file here? That will be the first 3 lines.
I wanna make sure what vendor daemon it uses and what port. For example, one of my older files looks like this:
SERVER servername 0012345678ab 7111
USE_SERVER
VENDOR sgiawd
Definitely uses sgiawd on port 7111. Yours might shed some light on the case.
Hi Travis,
Here is the top 3 lines
SERVER FLEX2.AERO.UND.EDU 005056AA1A70
USE_SERVER
VENDOR adskflex port=2080
Hi Travis,
No I have not. This is actually the first license I have tried putting on this server. This server does nothing else. Its purpose is to host licenses.
