Installation & Licensing
Unable to run Mudbox after one successful run.
10 REPLIES 10
Message 1 of 11
4218 Views, 10 Replies
I've recently installed Mudbox 2011 on my MacBook Pro. After installing for the first time, the program opened and I saw the product activation screen. I clicked to Activate it, but the program froze up and eventually closed (or I had to close it eventually, I don't remember specifically).
Open re-opening Mudbox, I was able to use the product and work. I saved a project, closed out and though everything was fine. However when I went to work on it again, I clicked the icon for Mudbox, it tried to open for awhile and I was shown an error.
The error reads:
License not obtained
Tried Mudbox 2011 (498C1 2011.0.0.F), error 2
License method: set by installer to 'standalone'
Lic. file override: environment variable MUDBOX_ALT_EN is not set
I've attempted to re-install Mudbox 2-3 times, even completely removing everything before hand. And I still get this error constantly, with nothing I can do to resolve it. Any help would be appreciated.
-N.
10 REPLIES 10
Message 2 of 11
david.lau
I would delete the following folders:
/Applications/Autodesk/Mudbox*
/Library/Application Support/Autodesk/Adlm/
I would delete the following files.  Do not delete any of the Adobe files in this folder!
/Library/Preferences/FLEXnet Publisher/FLEXnet/adskflex_00691b00_tsf.data
/Library/Preferences/FLEXnet Publisher/FLEXnet/adskflex_00691b00_tsf.data_backup.001
Reinstall Mudbox.  I would install it as trial first and then try to activate later.
NOTE:  This will also reset your Maya (Mac),  AutoCAD (Mac), Smoke (Mac) activations, so you may need reinstall all of the Autodesk software.
David Lau
Message 3 of 11
Ok, problem. I got rid of:
Applications/Autodesk/Mudbox.
But I didn't have:
or
I didn't even have a FLEXnet Publisher folder in Preferences. So...that's probably not good, right?
N.
Message 4 of 11
david.lau
Can you send me some screen captures of the subfolders?  It is odd that it doesn't show up.
David Lau
Message 5 of 11
RCdev
I`ve just registered to the forum because I am getting a problem when trying to run the Autodesk MudBox App.
I just bought my license of the Autodesk MudBox FULL 2012 - US595,00, did the download and installed everything okay...but when I run the app I get the exactly same message as the first poster here as follows bellow:
Tried Mudbox 2012 (498D1 2012.0.0.F), error 20
SO, What should I do???!! All this price for getting a ERROR?
So bad...
Please...some help would be very appreciated as soon as possible!
Rodrigo.
Message 6 of 11
david.lau
in reply to: RCdev
Are you on Windows or Mac?
David Lau
Message 7 of 11
RCdev
in reply to: david.lau
Hi David,
Thank you answering.
But I`ve solved my problem. Man Very Happy
Message 8 of 11
in reply to: RCdev
Well can you share your "solution"?
I have the same problem but cant fix it. Tried the first approach of deleting files and reinstalling them but to no avail.
Im running a Mac OSX and no matter how many time in reinstall or try different versions eg 2011 or 2012 i get the same error
A solution would be much apprecated
Message 9 of 11
Hi
            I'm using windows 7 OS when i install mud box getting error
Tried Mud box 2012 (498D1 2012.0.0.F), error 20
Lic. file override: environment variable MUD BOX_ALT_EN is not set
So bad...
cnayak22 ..............
Message 10 of 11
mine is getting the same problem.  I need a solution, and if anyone can give it to me that would be much obliged.
Message 11 of 11
TheR4man
I have been using Mudbox 2012 for months and suddenly error 20 appeared and I cannot finish my work. I tried your solution but my computer does not contain the files
and I'm running Windows 8.1.
I also installed 3 service packs for Mubox 2012 claiming to fix the issue.
Do you acuallty know how to fix this problem?
Administrator Productivity
