Installation & Licensing
Unable to Obtain a License from VM License Server
2 REPLIES 2
mathewkol
337 Views, 2 Replies
License manager is installed on a vitrual server, license file is installed, and LMTOOLS reports all licenses are available and 0 in use. Seems ok on that side. The VM has been assigned a static address.
Workstations, however, will not pull a license from that server, but they will pull one from one of the redundant servers in other cities. I have ensured that the servers are search in the proper order.
Any ideas?
Matt
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
2 REPLIES 2
TravisNave
in reply to: mathewkol
Ping the Server by name from the workstation and ensure that you are getting the right IP back from DNS/WINS. You also want to make sure that the ports 2080 and 27000-27009 are open in the firewall of your Server as well. If it is pulling from a redundant source, it's likely because it cannot find that server for some reason or another.
Autodesk Forums:
mathewkol
Thanks Travis. The port exceptions did the trick.
Matt
Matt Kolberg
Administrator Productivity
