Installation & Licensing
Unable to install. (says i installed already)
10 REPLIES 10
Message 1 of 11
qoo2345
15459 Views, 10 Replies
I starting have maya 2012 , and i decided to downlaod 2013 to see if i can open .ma files. Cause somehow i cannot open .ma files from my fren , only .mb. So i downloaded 2013 to see if it will solve my problem. So i downloaded the free trial version to test it out . I found out it is able to open .ma files .
So i decided to uninstall both maya 2012 and 2013 and reinstall 2013 to have a fresh copy . however uninstall 2013 halfway i found out it was not moving , so i ended the process , and i deleted all the maya programs files.
Now i redownloaded the installer and tried to install . it says that maya 2013 is installed already , and i cannot install it . I have check Control panel> programs and features , and see if there is maya still there . And there is none.
Any solution? tried multiple times in installing , and Restarted computer too.
10 REPLIES 10
Message 2 of 11
TravisNave
in reply to: qoo2345
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 11
thiagoandrade6
in reply to: TravisNave
Thank you "guru", you saved my life today with microsoft fix tool!!!
With it, I could removed the old installation and setup a new.
Thank you
Message 4 of 11
quentello
Thank you so much.
Message 5 of 11
JmPrsh153
fix it doesnt work on windows 10, says its not supported
Message 6 of 11
burningza
Thought I'll register and help others by adding my solution: Had the same problem installing Maya 2013 on Windows 10. The solutions/links provided does however not work anymore (broken url & Microsoft Installer Clean-Up Utility not working on Windows 10). I have however managed to fix the problem using Uninstall Tool v3.2 from CrystalIdea Software, which is free - http://www.crystalidea.com/uninstall-tool Hopefully this helps See screenshot of Uninstall Tool explanation: https://goo.gl/2cmOXF
Message 7 of 11
mensik20
in reply to: burningza
it doesnt work
Message 8 of 11
polvy
in reply to: mensik20
Problem solved with microsoft program, thank you so much.
Message 9 of 11
stroe14
Yes! The first link worked for me! Thank you very much sir, you saved my life!
Message 10 of 11
rybazbo
you are absolutely my hero! I spend more than 6 hours, restart computer million times and nothing. Then find your post and bum 10 min I have Maya!
Great Man !Heart
Message 11 of 11
TravisNave
in reply to: rybazbo
^ This is why I help people. 🙂
Autodesk Forums:
Administrator Productivity
