Hello.
I am having a problem with installing the above software. I am trying to stall it on a Windows 7 OS, in English etc. (The webpage gave me the options of 2013/2014, only windows OS and a number of languages, so I selected the appropriate ones where applicable)
However once I get to this stage, I am unable to go further. I investigated the problem, to find a service pack had not downloaded with the installation so selected the ‘Download Now’ option, in which it did so.
However in order to get the install button to light up and allow me to go ahead I have to unclick the installation of the main programme.
I have no other Revit version on my computer, as you can see I have enough space etc.
Little Help please?
Addtional Info: I'm a student, I'm downloading the free Sturdent version.
Solved by asburyj. Go to Solution.
Some of the product installers will make you close the configuration screen before proceeding with the install. Click that little Arrow at the top that says "Click to close and return to the product list" after making you configuration changed and the install button should light up again.
It's a failure when installing the microsoft visual C++ 2008. You might have a corrupt install or a newer version, Try uninstalling all your Microsoft Visual C++ 2008 versions and then re install from the links below.
Microsoft Visual C++ 2008 SP1 Redistributable Package (x86)
http://www.microsoft.com/en-us/download/details.aspx?id=5582
Microsoft Visual C++ 2008 SP1 Redistributable Package (x64)
http://www.microsoft.com/en-us/download/details.aspx?id=2092
