hi i m not able to install AutoCAD 2011 32-bit on my system, the setup starts but aborts saying .NET 3.5 is not installed on ur syatem...
2. I tried installing .NET 3.5 from microsoft website but is also not installing on my system and noting happens..
a message appears while installing "use windows turn on or off feature in the control panel...
3. My operating system is Windows 7 Home Premium 32-bit....
plz help
i tried to install it after turning off the UAC but the condition was same it is not able to install it only says .NET 3.5 is not installed use "turn windows windows on or off feature in the control panel...
in my system .NET 4 is installed.....
Un-install .NET from your machine and re-install using the copy available in the AutoCAD media.
Typically - <x86\support\dotnetfx> folder
If you encounter issue in un-installing .NET, then try third-party (non-Microsoft) utility which performs un-installation of all .NET Framework versions and cleans up left over files and folders. I have appended 1 of the many 3rd party utility available in the internet below. However, I wish to highlight that these are not an Autodesk or Microsoft utility so please assess the usage at your own discretion.
Information about this utility and manual uninstall steps :
http://blogs.msdn.com/astebner/archive/2006/05/30/611355.aspx
.NET Framework Cleanup Utility :
http://astebner.sts.winisp.net/Tools/dotnetfx_cleanup_tool.zip
hi i uninstalled the .NET using cleanup but nw on installing new error is showing up which is error 1935
i m attaching the screen shots of what i m seeing u can have a look...
Hi, Guys i am also not able to install Auto cad 2011 on windows 7....when i run the setup it says u cant install the software on the Operating System so what should i do ??
Your specific issue is different: you are installing the wrong AutoCAD in the wrong Windows.
32bit AutoCAD only installs in 32bit Windows
64bit AutoCAD only installs in 64bit Windows
You have access to both variants of AutoCAD as part of your purchase: get the correct one based on your Windows variant.
thanks mate....i have 1 Gb graphics card in my laptop so will this have any effect on the program ??
Depends on the brand, model, driver and what you plan on using AutoCAD for... .
