Installation & Licensing
Unable to borrow license
6 REPLIES 6
prem.savio
1512 Views, 6 Replies
AutoCAD Electrical 2015 & AutoCAD Mechanical 2015 are installed from the package PDSU 2015 on my computer. The software acquires the license from the server without any issues but when I try to borrow the license, the following error pops up. You cannot borrow a license at this time. Try again later. If this problem persists, contact your system administrator. Note: You can continue to use Autodesk Product Design Suite Ultimate 2015 while you are connected to the network license server. Error: [-5.414.0]
Tags (1)
6 REPLIES 6
TravisNave
in reply to: prem.savio
Do you know if there is an adskflex.opt options file that is preventing license borrowing from happening?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
prem.savio
in reply to: TravisNave
Hi Travis, Thanks for replying. And no, there is no adskflex.opt options file in the license server.
TravisNave
If you want to PM me your debug.log file from your license manager, I will take a look at it for you.
Autodesk Forums:
prem.savio
There is an interesting development to the problem. I have shifted one of the PDSU licenses from the old server to my machine (my machine is both, the server and the client now and contains 1 PDSU license). The license seems to get borrowed from my machine (current server) but it results in -5.414.0 license error when I try to borrow the license from the old server. Does this mean, the problem is with the old server?
TravisNave
Possibly. If you want to provide me the debug log file of the old server, I
will look at it for you.
Autodesk Forums:
Alriddin
I recently encountered a similar problem, however, I am able to borrow a license for up to 161 days, and can't borrow for the maximum period. If I select the maximum period of 180 days, as limited by the product, i get the same [-5.414.0] Error.
I am using both Infrastructure and Prduct Design Suite Ultimate, running Windows 8.1
Hopefully you can help with this.
Administrator Productivity
