Installation & Licensing
Unable to activate the software
3 REPLIES 3
ravbelgaum
408 Views, 3 Replies
Hi
I have downloaded the student version and installed successfully but when I tried activating the next screen is just two check box and full page is blank.
Please help not able to go to next page.
3 REPLIES 3
Hi ravbelgaum,
Did you encounter the same error as on this link? If so, please follow the troubleshooting steps provided to activate your License.
Let me know if you still have issues activating the License. Alternatively, you can also contact our Registration and Activation team for further assistance needed.
Joane Bonghanoy
FTO_1
in reply to: ravbelgaum
Hello, I purchased Algor Simulation 2010 in 2009 but am just installing it now - have been using an older ALGOR v23.1 since then but now urgently need the simulation 2010 capability.  I  installed the softwar but upon trying to register/activate it said the serial number I entered was not valid.  This is the serial number provided on the box with the PURCHASE.  I need this to be fixed right away as I am up against a deadline.  I find it very difficult to find a customer support number.  Who can I talk to to fix this immediately?
Thank you,
Frank Owens
518-438-9242
TravisNave
in reply to: FTO_1
Welcome to the peer forums, Frank.
If you purchased Subscription and it lapsed, or if you upgraded or crossgraded to another newer version, your 2010 might be expired.  You need to contact the reseller that you purchased it from, assuming you purchased it legally.
Autodesk Forums:
Administrator Productivity
